查看: 13054|回復: 1
QQ勛章墻全版本通用補丁v2.0 (附源碼) 配圖+下載地址
發表于 2017-12-14 10:58:46 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本工具非寫入預定文件,而是在當前版本的dll基礎上修改,保證了穩定性
在騰訊修改勛章墻功能前,本工具是可以一直用下去的
本地測試通過,測試環境:winxp,windows10 x64
python編譯版本:2.7.14
下載地址:https://pan.baidu.com/s/1hsnJVdq 密碼:boav
使用方法:
1. 下載exe直接運行即可,無需關閉QQ。
2. 電腦有python環境的下載源碼,自行運行。
#!/usr/bin/env python
# -*- coding:utf-8 -*-
import os
import _winreg
from time import sleep
import subprocess
Debug = False
version = '2.0'
def main():
    qqdir = ''
    dllfile = ''
    try:
        if ('PROGRAMFILES(X86)' in os.environ) == True:
            key = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, "SOFTWARE\Wow6432Node\Tencent\QQ2009",)
        else:
            key = _winreg.OpenKey(_winreg.HKEY_LOCAL_MACHINE, "SOFTWARE\Tencent\QQ2009",)
    except WindowsError, e:
        print('can\'t find qqdir, maybe not install')
    else:
        qqdir = _winreg.QueryValueEx(key, "Install")[0]
        if Debug == True:
            print('[Debug] ' + qqdir)
        if qqdir != '':
            dllfile = qqdir + "\\bin\\OPMiscDll.dll"
            print('[Info] qqdir: ' + qqdir)
            crack(dllfile)
        else:
            print('[Error] can\'t find qqdir, maybe file is missing')
def crack(path):
    print('[Info] find file succeed: OPMiscDll.dll')
    print('[Info] start kill progress: QQExternal.exe')
    cmd = "taskkill /F /IM QQExternal.exe 2>nul 1>nul"
    ret = subprocess.Popen(cmd, shell=True)
    ret.wait()
    f = open(path, 'rb')
    filecontent = f.read()
    f.close()
    byte = bytearray(filecontent)
    if len(byte) == 0:
        print('[Error] read file failed: OPMiscDll.dll')
    else:
        result = modify(byte)
        if filecontent != result:
            g = open(path + '.new', 'wb')
            g.write(result)
            g.close()
            if os.path.exists(path):
                if os.path.exists(path + '.bak'):
                    os.remove(path + '.bak')
                sleep(1)
                if Debug == True:
                    print('[Debug] ' + path)
                print('[Info] backup file to OPMiscDll.dll.bak')
                os.rename(path, path + '.bak')
            if os.path.exists(path + '.new'):
                print('[Info] build new OPMiscDll.dll')
                os.rename(path + '.new', path)
def modify(byte):
    index = find(1, 0, ['b3', '01', 'eb', '02', '32', 'db', '0f'], byte);
    if (index != 0):
        index2 = find(2, index, ['ff', 'ff', '8a', 'd8', '0f', 'b6', 'd3'], byte);
        if (index2 != 0):
            index3 = find(3, index2, ['32', 'db', 'eb', '02', 'b3', '01', '0f'], byte);
            if (index3 != 0):
                index4 = find(4, index3, ['b3', '01', 'eb', '02', '32', 'db', '0f'], byte);
                if (index4 != 0):
                    index5 = find(5, index4, ['00', '00', '8a', 'd8', '0f', 'b6', 'd3'], byte);
                    if (index5 != 0):
                        index6 = find(6, index5, ['00', '00', '8a', 'd8', '0f', 'b6', 'd3'], byte);
    if (index != 0 and index2 != 0 and index3 != 0 and index4 != 0 and index5 != 0 and index6 != 0):
        byte[index] = int('b3', 16)
        byte[index + 1] = int('01', 16)
        byte[index2] = int('b3', 16)
        byte[index2 + 1] = int('01', 16)
        byte[index3] = int('b3', 16)
        byte[index3 + 1] = int('01', 16)
        byte[index4] = int('b3', 16)
        byte[index4 + 1] = int('01', 16)
        byte[index5] = int('b3', 16)
        byte[index5 + 1] = int('01', 16)
        byte[index6] = int('b3', 16)
        byte[index6 + 1] = int('01', 16)
        print('[Info] patch succeed')
    else:
        print('[Error] patch failed, maybe it already patched')
    return byte
def find(id, index, param, source):
    result = 0
    for i in range(index, len(source)):
        if source == int(param[0], 16):
            if source[i + 1] == int(param[1], 16):
                if source[i + 2] == int(param[2], 16):
                    if source[i + 3] == int(param[3], 16):
                        if source[i + 4] == int(param[4], 16):
                            if source[i + 5] == int(param[5], 16):
                                if source[i + 6] == int(param[6], 16):
                                    if id == 3:
                                        result = int(i)
                                    elif id == 2 or id == 5 or id == 6:
                                        result = int(i + 2)
                                    else:
                                        result = int(i + 4)
                                    print('[Info] find ' + str(id) + ': ' + str(result))
                                    return result
    return result
if __name__ == '__main__':
    print("[Info] ==========================")
    print("[Info] http://www.52pojie.cn")
    print("[Info] ")
    print("[Info] medalwall patch... v" + version)
    print("[Info] ")
    main()
    print("[Info] all mission done, Press any key to exit...")
    import msvcrt
    while True:
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;if ord(msvcrt.getch()) < 255:
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;break
發表于 2017-12-15 19:15:34 | 只看該作者
的點點滴滴多多多多多多多多多多多多多多多多多多多多多多多多多多
GMT+8, 2025-3-13 20:54 , Processed in 0.083187 second(s), 26 queries , Gzip On.
主站蜘蛛池模板: 午夜麻豆国产精品无码| 亚洲AV无码成人精品区狼人影院| 久久国产亚洲精品无码| 无码精品日韩中文字幕| 日韩精品成人无码专区免费| 国产真人无码作爱免费视频| 天堂Av无码Av一区二区三区| 精品人妻少妇嫩草AV无码专区 | 日韩精品无码免费专区午夜| 亚洲精品无码永久在线观看你懂的| AV大片在线无码永久免费| 亚洲va无码va在线va天堂| 亚洲精品无码av人在线观看| 人妻少妇精品无码专区漫画| 无码人妻一区二区三区免费n鬼沢 无码人妻一区二区三区免费看 | 狠狠久久精品中文字幕无码| 亚洲av无码片在线观看| 日日摸日日碰夜夜爽无码| 午夜无码视频一区二区三区| 精品无码久久久久久久动漫| 无码人妻一区二区三区兔费| 日韩精品无码一区二区三区不卡 | 亚洲AV永久无码区成人网站| 色欲AV无码一区二区三区| 中文无码精品A∨在线观看不卡| 亚洲va无码手机在线电影| 中文字幕无码日韩专区免费| 国产日韩精品中文字无码| 特级无码a级毛片特黄| 噜噜综合亚洲AV中文无码| 2021无码最新国产在线观看| 无码一区二区三区视频| 亚洲欧洲美洲无码精品VA| 亚洲精品无码高潮喷水在线| 波多野结衣AV无码久久一区| 国产丝袜无码一区二区三区视频 | 亚洲国产成人精品无码区在线观看| 无码日韩人妻AV一区免费l| 无码 免费 国产在线观看91| heyzo专区无码综合| 国产亚洲?V无码?V男人的天堂|
